Same as above
Just bought an S80 GSR trans. Was told it grinds 2nd. From 1st to 2nd if i wait a bit it will just click into 2nd, if i try right away it grinds but goes in. Its impossible to down shift into 2nd without bad grinding. I opened it and the synchro was pretty bad and the dog teeth were chewed up. Would I need the slider, synchro, and 2nd gear(new of course)? I dont have the money now thats why i just closed it up and ran it. The parts are about $250 from synchrotech and $100 for second from honda.
1996 Civic Type DX
You need a CS 2nd, 2nd synchro, 1/2 slider, maybe a 1/2 hub, and maybe a 1/2 shift fork. What does the hub look like and what is the fork thickness?
You can order all the parts through me if you'd like.
Same as above
The shift forks all looked good hardly any wear. I didnt get far enough into it to look at the hub, or the slider for that matter. I just figured if the dog teeth were worn the slider must be also. I dont want any down time on this at the moment. I want to enjoy my car for a while before i take it down again. I havent driven it for over a year. When it comes time ill price it out with you. Once i tear it down.
I think I have carbon 1-2 and hub from ST, you would need a 1-R-2 slider, left over from GSR masterkit that I didn't need all the parts, Like Chris has done the exact same thing :)
