1 - 4 of 4 Posts
94 del sol
Hey does s300 have a basemap that can be used until i get a tune? i heard they do have one but it has to be modded based on injector size and cam profile
Ya thy have basemaps with s300 yes you need to change it for what ever injectors you are running. The tuner will fix the problems with cam profile. A basemap is crap just lets you drive to your tuner at low rpms.
the s300 had base roms (p28, p30, p06, ect... ), they have included some "tunes" for popular set ups like a supercharged d, and so forth.. but those are not that great either (two identical motors/setups in different areas ... even in the same area sometimes.... will tune different, always remember that!!). your best bet is to just plug in your setup based off the rom your going to use (p28 or so) and get your car started and get to a tuner to make it right. just start a new map with p28 (for example) and add in your injector size, map sensor, and the basics. it will start your car, but dont boost it.. drive out of boost to the tuner. good luck
1 - 4 of 4 Posts
