I need a D16a6 base map. It is a Vitara with FJD I beams, t3/t4 .48 .50ar. 880 injectors and a delta 257-272 cam.
Just need to drive the car home after we get done puting everything on. My tuner is out of town until Monday that is why I ask.
Thank you
95 ex coupe
cant tow it?
that would be your best bet. that way nothing gets hurt in any way.
but i understand if you dont have a trailor cause i been there before.
maybe try hondata.com and look at the forumn part maybe something in there to really help you out. if anything make a name and ask someone on there to make one if no one here
1997 Honda CRV
I can set you up with a basemap, but its really not a good idea to have someone do unless the car is infront of them. I will also take zero responsibility if the driver feels cocky on his basemap and blows it up. Base maps do not cause cars to blow up, retarded cocky drivers do.
can you guys tell me what numbers do u have in your fuel maps when using 680 + inj for the idle ? -18 @ 750 rpm for example
