1 - 20 of 44 Posts
Nor Cal D-series rider
1991 Honda Civic STD
For my EF's 1st oil change, I went with Mobil 1 5w20 oil. The filter it had was a Wix (Napa Gold). I wanted better flow & filtration and some added JDM bling & took Stevo-O's idea of using the S2000 filter (Honda Part# 15400-PCX-004). Luckily, it fits both hatch & Integra! After switching to the Toyo Roki, my car ran smoother & slightly cooler & after 1600 miles, the oil still looks clear and amber. :TU: The only downside is price; Almost $10 thru :honda: dealer, WAY cheaper online; $7 or so. If you want a larger filter element unit that does a slightly better job filtering, buy the Purolater Pure One filter, it's supposedly the best one out. I chose the Honda unit for brand loyalty and those cool Japanese characters on it! :D http://www.handaaccessories.com/s2000-04.html
Adia's Daddy
2004 Honda Element
kommon_sense said:
somebody needs to cut one of those things open...
i have one on my car now kommon so when oil change time comes this spring i'll bring it to work and disect it for fun
Glad its workin out for ya man. I was kinda worried for a while there to suggest it because i didnt want to feel responsible in some way if something happened but a ton of guys use them religiously on h-t and i have one on my eg as well and its worked fine for me. the guys at the dealership make fun of me because i use one and i cut filters open in my boredom time. they kept saying the filters are all the same so one day this week when things were slo i cut open the honeywell/fram one we use daily for oil changes and the filtech units which comes installed on brand new hondas from the factory. lets just say in a matter of 15 minutes with a small air cutting wheel and some brake cleaner, i had proved my point :TU:
all hondas used to have a filter of that size at one point and the dealership used large ones for oil changes all the time. then honda went to the smaller one for some reason but im not buying it.
wheni bought my filter a while ago they were like $38 a pop over the counter at the dealership. i checked the other day because they always keep one in stock and they've reduced the price now to $8 :eek:. i asked rob if i pull mine off the car and return it for a refund and new one :p
Steve-O, I rack up miles like a World Rally Championship driver so I might change my oil in not too long. I'll saw the mofo in two and post pics if I ever get my digicam back...What does a Purolator Pure 1 filter cost anyways guys? :jdm:
Adia's Daddy
2004 Honda Element
kommon_sense said:
anyone have any more detailed pics like ones showing the # of holes, etc.? Also any dimensions. That pic looks like a regular civic sized filter.
here you go man:
Also, here's an internal cut-out view of the HAMP filter which is supposed to be exactly the same as the S2000 unit:
D-series wise guy
Adia's Daddy
2004 Honda Element
Seeing as how I handle about 16 of the small filters a day and i look overt each and every one before i install them (which is one reason why i don't use them :???: ), the easiest way to tell the diff between the small and large filters from pics on the net (which tend to be deceiving more often than not) is the gasket location. on the small filters the gasket is much closer to the edge lip of the metal filter body whereas the larger ones tend to be more inwards.
Newer smaller filter:
Older large style:
Sorry for so many pics. Hope this helps
Adia's Daddy
2004 Honda Element
kommon_sense said:
good finds man :TU:. i was reading your thread on sohchonda and hamp now makes the small size filters too. im guessing that the low oil pressure situation only happens in the newer civics but it might occur in 95 and olde rmodels as well. id have to see a cutout of the small hamp filter before i buy into the small filter trend. im sure honda wouldn't use it if it was harmful to the engine however is it possible that it could be the "band-aid" for a poorly designed oil pump as you mentioned?
i guess until someone shows me that the large filters are detrimental to the operation of the engine i'll keep using the large ones as long as they make them. if i have to go down to the small size i'll buy the small hamp units.
hey kommon, another good site if you're really interested in oil studies and filter cutouts is this one kommon:
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=6;t=000723;p=1
you can also find some good info in the thread i started :beer: :
http://www.d-series.org/forums/showthread.php?t=14012
C
searching
Hey just got myself a 2005 Civic Coupe EX and wanted to know what you guys thought was the best oil and filter for my car.
d17a2 engine says that it requires 5w20 and I've never heard of a car using that kind of oil (been driving a 1982 Datsun 280zx for the last 8 years and it took 10w30 every time!). From what I've read in all the threads in this forum is that Mobil 1 is the way to go. (synthetic! Oh my it's the future and stuff!) and that I should do away with my fram filters and get the s2k filter from honda. Does this still ring true with this newer car? I have also read that there are oil pressure problems with the s2k filter in newer civics. What to do what to do?
thanks guys...glad to be a part of the honda community! :)
Adia's Daddy
2004 Honda Element
welcome man and congratualtions on your purchase :TU:.
5w20 is the proper oil for your car. im the minor service tech at our local honda dealership and and all ther 2001 and up civics here in canada take 5w20. yours should take approx 3.2L if its non-VTEC and 3.5L for VTEC versions. you'll have to convert that to quarts because im on metric system up here :p.
as far as a good oil, you'll hear as many choices as there are grains of sand on the beach. mobil 1 gets alot of good reviews and i used it before i went to redline 5w30 synthetic in my civic (then again, im VERY hard on my car and its only a 1.5L non-vtec d15b7). i used to run castrol syntec but i found my valvetrain always looked dirty and sludged up with it. reading up on the net i found out that i wasn't the only one who noticed this. our dealership a while ago even got its bulk oil for services from castrol but they found the same sludging/darkening issues and changed to petro-canada bulk oil. now i see engines come in looking alot cleaner than mine did back then. the only thing with your civic being so new be careful what you use so you dont run into warranty problems. i know how honda can be and if you use different stuff in your car other than honda's until the warranty runs out they might try and be sticklers if something goes wrong.
the s2k filter will fit on your civic but honda has gone to the smaller filter across the board except for the s2000 and the hybrid insight. im not quite sure exactly as to the oil pressure issues but if you'd like to stick with a smaller filter and want a better one than the over the counter frams they use now at all dealerships, the jdm HAMP one (green) come in a small size. form what ive seen and invesitgate myself its made for hamp by toyo roki. i had a new car come in for its first oil change and i kept the factory filter that came on it (it was made by toyo roki and said so right on the side) and cut it open one lunch hour for fun. it was exactly the same as the jdm green HAMP one. the hamp filters can be purchased on ebay and from many jdm retailers.
honestly, if you are just using your car to commute to work and back and be a family transport vehicle, you won't be done wrong with using the oem honda filter and oil you get from the dealership on regular services. however, if you plan on using your car for anything harder than normal daily driving, like to have "fun" or even compete in motorsport activities with it, synthetic and the jdm hamp filter would be a great combination. mobil 1 or redline would be my two choices as far as lubricant. fair warning tho, i find redline is quite pricy. this hoser pays $13 a litre at canadian tire here in ontario :eek:. the guys at work make fun of me for it and ask why i dont use the stuff out of the lines and the regular honda filter. im sure it would suffice but im not about just follwing the standard or using "what'll do". im picky about my car and what i put into it. even if it is a bit overkill, i like knowing my car is ready for whatever i throw at it because peace of mind is a wonderful thing.
anyways, not sure if this may have helped you out or made things more complicated. best bet is to ask around and surf the net for more info. oil and filter choices will all depend on your needs from the car and driving habits. listen to some more replies from other people on here and then make some decisions.
have fun man and welcome to the honda community and d-series :TU:
C
Actually I have already read a lot of things that you had to say about your job and your activities there :) Thanks for replying! I was beginning to think that this thread was just dead.
Yeah...I'm just like you as far as my cars are concerned. I usually try and pamper the little bugger. I just didn't know oil made a difference at all until just last week and I stumbled upon some threads on the subject. I'll be changing the filter and oil in my 280zx as well as the stuff in my new car. I'm thinking that mobile 1 will be where i'm headed but if I can find redline at Sam's or something I'll get me some of that :) I'll have to make a point to order a hamp filter as well...I'm a little concerned about the oil pressure problem but if there are smaller filters out there that are still high quality I'll be using that. Thanks for the advice!
Now all that's left on my list of future upgrades is finding a good head, and a good intake. My priority 1 is fuel economy so I'm compiling a list of products that will either not effect my consumption or lessen it. I've had the mechanic bug for going on a decade and it's not stopping now...but I'm considering it a personal challenge to collect pieces that will improve my fuel economy AND performance...if any exist that is...any ideas people?...hmmm...maybe I shoudl start another thread on this...
if you go with the smaller filter, make sure you have a tool that can remove it in the future. ALL of my autozone oil filter wrenches WON'T fit around the thing. I ended up having to smash the crap out of it to get a firm grip to unscrew. I think honda sells their own tool though... but I went back to using Purolator filters.
Lifetime Awesome Member
'89 CRX HF
it really shouldnt be so tight that you cant unscrew it by hand. spin it until it stops, then go about a half turn more. thats all you need. then when you go to take it off, you dont need a wrench or special tool
Adia's Daddy
2004 Honda Element
from what i have read and understood, simply changing oil won't make the difference. its the longevity issues and driving habits which separate them all. now, if your grandparents had two 1998 accord sedans, one with reg oil and one with synthetic, im pretty sure they will probably have just as good performing an engine in either for the life of their car (or them for that matter).
now, put two same two cars in the hands of younger, more aggressive drivers for the next 15 years and i think the synthetic would be a better contender. mind you, there are other factors to consider however all things being equal, id prefer synthetic in all my cars over regular oil. but then you get into the whole "which snynthetic is better" debacle and thats where things get fun :p
hamp does make the small filter and the large one as well. the sk2 large filter is the same as the jdm green hamp large one and since i work at the delaership i get the s2k units for ridiculously low price (thanks honda :TU: ). K&N makes a very impressive filter as well and is similarly priced however im not quite sure of they have a small one yet for the newer hondas. your local auto parts store which sells the k&n filters should have a book there telling you whats available.
id prefer to stick with oem honda or hamp just because its made for your honda already. that whole peace of mind thing again.
p.s. actually, i don't pamper my car...im pretty aggressive with it but i rtake great care and concern with what i put into it so i can keep it going the way it has been ;) :p :TU:
C
Don't want you to get the wrong Idea...I beat the hell out of my car sometimes...I just like that everthing I DO to it is as close to the best/perfect as possible. And I don't set drinks on the hood and stuff like that :)
1 - 20 of 44 Posts
