E
maybe not the right codes but do the eg ex/si trannys have shorter gears than the ek trannys?
E
sorry man, didn't know i'm new. i was just lookin for some help
E
so ex/si have shorter gears compared to the lx dx and cx, but the vti is the way to go
DirtyDEF said:
P20-A000 = DX/CX/VX
P20-B000 = EX/Si
http://www.hondaswap.com/forums/index.php?showtopic=29829
Scroll down for 5th/6th gen.
Info on that link is incorrect, esp in the 5g section.
Why you say? They copied my errors :)
5g vs. 6g EX trannys have the same gearing, 5g Si/EX 4 door got .750 5th gear.
I know the 5g -6g second gear are different, 1.900 vs. 1.909, but it isn't enough of a differnce to matter.
Where it all began.........
http://home.cinci.rr.com/mistab0ne/tranny.html
that was posted on WebTV before I moved to a PC in 97-98 :)
BTW, while there is some info incorrect, which I did send the corrections to the poster, it is the most correct info that I know of.........
I know this is an old topic but please forgive me.
I currently drive a 1996 1.4iS Civic with an S40 tranny.
If i compare the gears with the L3 gearbox i drove before the S40 gears are much longer.
In the 4th gen Civic with D15B2 the engine made over 4000rpm when i was driving 120km/h, with the '96 1.4iS i the engine is making about 3200/3300 rpm on the same speed of 120km/h.
Can someone confirm what the gearratio's are from de 5G S20 gearbox and the S40 6G gearbox?
