Which is better? I currently have the S20. I'm about to buy the S40 for $100 unless it's crap. Someone give me some insight with this one.
Thanks
BUMP. A little help!?
S
modsHXcivi said:
S20 has a closer gear ratio ......S40 has longer taller gear ratio
last i checked the gears were the same. idk.
the s40 has thin steel shift forks which bend and the s20 has aluminum shift forks. as stated in a previous thread, take ur pick on whether u want the steel forks eating up the gears when it gets bent or u want the aluminum shift for to break but not really eat up the gears. the s20 is from the 92-95 ex civics and the s40 is from the 96-00 ex civics i believe... hope that helps u out
yes it does. thanks fellas
