1 - 12 of 12 Posts
98 civic DX
D16Y7 just replaced the head gasket and had the head redone. Runs great, but after driving it still wants to run warm. No signs of it "overheating". I sit that hard to purge the cooling system? I'm missing something, i know it. Any ideas or knowledge would be much appreciated.
front end up on ramps/jacks.
remove radiator cap.
start car.
wait for fan to cycle at least twice.
turn heater on full blast.
keep eye on coolant level and keep overflow in the normal range
98 civic DX
Discussion Starter · #5 ·
The complete cooling system is new. Honda oem t-stat and sensors. Ill try that bleed process. I did not have the front of the car lifted when i did bleed it. Thank you for the info.
98 civic DX
Discussion Starter · #8 ·
It does. I have witnessed the fans cycling on. So i know it works. If i turn the heat on it will bring the temp down.
I had a heater leak that only showed up when I looked under the car about mid way. I used the dye but found it once I looked a little harder for it and didn't really need the dye. It ran through the underbody channel next to the brake line protective covering channel and came out a little factory punched hole. The overheating drove me crazy for a bit. I just did a return on the hose as I live in SE FL and don't need the heater. It's worth a look.
It was so small that it all but evaporated before it would turn up as a steady drip and was far enough back underneath that it wan't readily visible.
1 - 12 of 12 Posts
