1 - 6 of 6 Posts
What going on guys having a issue with vehicle rpm the vehicle is a 1998 honda civic ex auto .after the vehicle timing belt got destroyed while driving the head bent a couple valve. After a couple of week i found a replacement head the was in great condition from a friend i decide to replace the head. Ive done it a couple of time before so i went on ahead and replace the head everything was a success after car turn on with no issue. After driving it for 3 day i notice that the rpm will shoot up to 3k and stay their. It will stay accelrated then it will go away found the throttle cable to tight so i went and adjust it. After that 2 day later and now a common problem my rpm will shoot down to 300-150 rpm and when u punch the gas the car wont move or move so slighlty. So i went and adjust the cable so thigthen it o so little just where my rpm is at 500-600 and i also clean the throttle body reomve alot gunk in it after doing that. A whole passed by with no problem till today where rpm dropped again and it wont move. It seem everytime i adjust the cable it will work for a lil bit amd the go bad has any ever encounter this type of issue before swapping a head or just in general. Sorry for the big story i wrote up but im try to give you guys all the detail i can please help this is getting very annoying adjust the cable
\/Your Mom Was Here\/
Vibe GT
Quit adjusting the cable and leave it so it doesn't pull the throttle plate at all. You have an issue with something or somewhere in the swap. Likely a vacuum leak, spray some carb cleaner near the TB and intake and see if the RPM's change, if you hear the motor respond to it than you have a leak and need to fix it and start again.
Also bumping a thread on a really slow forum (within 2 minutes) on a Saturday when most of us have real shit to do is just annoying.
also, did you bleed the coolant afterwards? timing correct?
Reactions: buzzbomb
97 EJ6 boosted D16Z6
del Sol si '94
Like BeerDrinkin said, sounds like a vac leak. Could have the throttle cable too tight, or even a bent tb blade(unlikely unless you had a nitrous backfire!) Also try the adjustment screw on the top of the tb slightly.
1 - 6 of 6 Posts
