1 - 4 of 4 Posts
D16Y8, manual, P28, HTS basemap. It runs perfect and idles fine, but when I let the gas off and pressing the clutch (no load on the engine), the rpm drops to 0, sometimes the car shuts off and sometimes it recovers itself.
What can I do to fix it through HTS or some mechanical stuff, like adjusting throttle screw or advance ignition with the distributor or something?
Thank you.
'93 / '95 Del Sol Si - '95 DX Coupe - '00 Accord EX F23 Manual
Just to clarify -
You were driving the car prior to this and it was fine, correct?
Also - Were you running a chipped ECU before this and running a different basemap?
Also also - Did you change anything before this? Intake mani? Throttle body? Anything?
Discussion Starter · #4 ·
Thank you for your comments. I have fixed that with adjusting the screw on the throttle body, and than adjusting the idle rpm through the ecu.
1 - 4 of 4 Posts
