1 - 7 of 7 Posts
1995 Honda Civic DX
Installing a t3 .42 .48 on a d15b7 with ac and 450cc injectors... everything is bolted up...fire it up starts...but sounds like its missing... as there is a small leak probally from the block fitting... my question is what could be causing the missing sound? wired wrong injectors? not having the colder plugs in?
1995 Honda Civic DX
Discussion Starter · #4 ·
ill check my base map again but when i checked it, it was a lil rich...
'95 Civic dx
if its missing at idle, it is possible your timing is too advanced... just an idea check that too... at 800 rpm and -21" my timing is 16*
1995 Honda Civic DX
well it was the injectors or the wiring...we switched them out to 310s and it idle fine...
1 - 7 of 7 Posts
