1 - 6 of 6 Posts
this is my first time building a motor for performance, and not just for DD, anyways, i am having clearance issues in my z6 block with eagle rods, clearance issues with the side of cylinders, any help would be great.......
Thanks
racist-bigot-sexist-homophob
You have to notch the block. Search and you will find the info or check out www.theoldone.com
Yep, grab a rotary tool and have at it! Good idea to grab a couple carbide bit too! You might also need to clearence the girdle depending on whether you've got the ARP 2000s or not.
Good luck!
1 - 6 of 6 Posts
