1 - 12 of 12 Posts
Honda
I have crower rods with crower rod bolts.........they are the steel billet i beams.....
anyway, im building for 300whp, if that matters at all. I was needing to know what to torque the rod bolts to? sotck, or is there a reccomended amount for aftermarkets on high hp apps?
also, besides the rod bolts, is there any other special torque specs to follow other than stock reccomendation on a build like this.....thanks
Honda
i torqued my ARPs to 37lb/ft
how is that compared to oem spec? i dont have a chiltons here with me right now so i cant compare them.
thanks for the info by the way.:TU:
Honda
my manual is in my parent's garage, so i dont know. lol
oh, well right on, its cool. im sure someone will chime in here in a bit with the answer.
thanks for the help though
do you think the crower and arp bolts should be torqued pretty close to the same?
thanks again for the help:TU:
Honda
i called crower today and they said for the 3/8" torque to 45 ft/lbs. for a 5/16" torque to 25 ft.lbs
i guess i need to find the bolt stretch, ill call tomorrow and ask them
thanks for the help everyone
1 - 12 of 12 Posts
