puttin a new set of rod and mains in my d15b7...i read somewhere that the rods were 23lbs and rods were 33lbs..is that right??sounds kinda low to me but wanted to get everyones info
So I'm going to start that I need a new starter and dizzy for sure but cause I hook up a z6 harness to a y7 block ? And I'm thinking about just getting a z6 block and putting it in
Need a second opinion here:
I have an 89 CRX Hf that had working AC, not amazing, but it worked. I assume it was R12 as there were no converter nipples going on.
A while back someone hit let head on, broke the radiator and mangled the condenser, but didn't rupture it.
I decided since I was...
Hey all,
Long time reader, first time poster.
So, I have a 1995 Civic Ferio Vi, with a D15B (two stage vtec) engine in it. Imported from Japan, so all JDM parts.
But... Something backed off the bolt on my main pulley (AKA harmonic balancer), and it got damaged. So, now to find one.
Partsouq...
For you say anything I've done the search of done four searches and after getting to the 20th page I give up . My plan is to use a D15B7 and put the Max peating rod rods which are higher at 134.5 mm which is only at half a millimeter larger than stock rods. Along with this I plan for a z6 head...
