1 - 20 of 34 Posts
93 maybe 94 coupe
Was reading original post on shock replacements and didnt wanna hijack the thread so here we are.
I inherited this neglected car w a strong stock JDM d15b and after manual swapping it, manual rack replacing it, AC deleting it and lightly weight reducing the front end it now sits like I'm hauling a** when I'm sitting still.
Rear ride height is about the same. Here's my only pic. (phone is full)
So.... I was gonna use OE sport h & r springs, but they are advertised as an even .75 inch drop all around.
Thoughts?
Some refer to the h&r sport springs as "slammed on nutz" and say the ride "isn't too bad" and even I remember a friend's car that ran them and they weren't TOOOO bad.
But they'd drop the front more than the back, problem solved.
Then I come across this h t thread
Bilstein HD with H&R OE Sport Springs - Honda-Tech
Do bilsteins really let you adjust an extra 3/8th inch out of the ride height? Or is that an adjustment for length if ur running really low and need a shortened damper?
I had a brief desire for reds, but my bilstien monotube experiences have been great in other applications so I'm totally down for some good german nonadjustable dampening. I just need to figure out my best spring bet so I can put on these rims I got a deal on off a totalled ek : )
93 maybe 94 coupe
Also considering h & r touring kit, but don't know much about their dampers. The great ride of the bilstien dampers and their reputation for quality are attractive.
Really no thoughts here?.... Lol I guess I only gave it like an hour
\/Your Mom Was Here\/
Vibe GT
H&R OE sports will lower it about and inch or just under, good for older civics . I have some Eibach Sportlines on my 2005 civic. They sit fairly low and ride decent but my shocks are blown. These are more aggressive at 1.5 inch or more of drop. Just remember not to judge your springs right after installing them, they will set down more after a few days. My civic for reference. Don't forget to order rear adjustable UCA's when you get springs so you don't butterfly the rear wheels.
EDIT: I don't know where you are from but most of the users here are based in the US and are usually not online at midnight. Like I said most.
93 maybe 94 coupe
After my experience w hr springs I'm pretty sold on them I'm more tryna figure out if the bilsteins really have an adjustable perch. I don't really know what I'm looking at in the pics of the bilstien shocks near the bottom of the HT post.
If indeed they allow a bit of extra drop like koni yellows they are the perfect solution for the pothole ridden and cobblestone streets of my neighborhood in Tacoma.
93 maybe 94 coupe
Also quite concerned it will continue to sit in a tail dragging manner if I do a straight .75 or 1.5 inch drop. Anyone ever have a similar issue after power steering / AC delete?
It currently looks like I'm pulling a trailer thats got too much tongue weight for my truck.
Vibe GT
I have never seen an adjustable perch on a strut before that wasn't a coilover... If you want something like that then get a set of Ground Control coil overs and run the shocks/struts you like.
EDIT: Almost all civics lowered or not sit up higher in the front.
93 maybe 94 coupe
I think that it has a second groove machined into the body for the front perches to be installed at different heights. I have read that even without these, you can have a new groove machined onto the body after the fact, but I don't want to do that if I can avoid it.
I wasn't talking like a threaded adjustment like on a coil over.
Lacking info on the h&r touring cup kit, I might just go w the bilsteins and the lower h&r sport springs which should level it out. I don't really want that much drop though.
93 maybe 94 coupe
Anyone have experience w running the touring cup kit or any experience with h&r shocks?
Tape-R taper/driver
EC3, ED8, ED9, EE5
I highly doubt an OTS drop-spring from a reputable company like H&R is going to provide too harsh a ride. In the case that it does, it is more likely to be under dampened or the OE shock is too tall and the shock is actually bottoming out.
If you are trying to even the car out, why are you trying to do it by using static springs?
Get a set of adjustable coilover sleeves and adjust the height until you are satisfied.
Vibe GT
Exactly!
Ground Control coil overs are very good for a cheap alternative. Choose a spring rate and set of shocks and go from there.
93 maybe 94 coupe
So is that also partial votes for the hr cup touring kit then since it's matched and height adjustable? Idk enough about springs and rates and FWD handling to be deciding rates on my own.
In terms of leveling it out, it's OK if it's close, I just don't wanna spend 600$ for something that leaves it the same stance, an inch lower. Height adjustable and convenience might win out here
Comfort is a priority, hence my original plan for h r OE sports.
Vibe GT
You can get some 350-380 rate springs and they would be decent, a little stiffer than stock but not by much. If you get some linear springs like how the Eibachs are then it won't get a lot stiffer until it compresses the spring more. I am not sure about H&R but I would assume they are linear as well.
93 maybe 94 coupe
I'm waiting for a response from bilstein USA about their take on lowering springs like the h r sports and their b6 HD shock. According to my research the stock length shocks are good to 40mm drop which is right near the 1.5" and 1.8" drop of the sports.
I'm not tryna go coil over though, I want the engineering done by professionals. Preferably German ones. If i am stuck w dual tube shock design I will go w the matched height adjustable kit.
93 maybe 94 coupe
The h r sports are progressive and within 30% of stock, but actual rates are hard to find.
Tape-R taper/driver
EC3, ED8, ED9, EE5
Springs are springs... the ride quality is going to come from the damper, mostly.
With the weight of an EG coupe, I would suggest something around 350-400 front and rear if you are wanting a little performance or 350-400f/250-300r if you are wanting it to be lower, but still a decent ride.
The harshness in ride comes from an oversprung or underdampened rear axle most of the time.
93 maybe 94 coupe
See I've run progressives before and combined with a modest dampening increase they really ride as well or better than stock, one reason I have so much faith in h & r as a product.
Same goes for the monotube bilsteins. In a newer focus it made the car feel like it was way nicer than it was. If they can take the ride height of the sport springs I can't imagine I would be disappointed.
93 maybe 94 coupe
Discussion Starter #18
Pretty sure I ran across rates for the sport springs and they were in that decent ride range specified above.
Koni and Eibach are German companies, just like Thyruss-Krupp Bilstien, but also have US production locations.
Bilstein = Fairfield, OH. 5.5 miles away
KoniNA = Hebron, KY, across the river and through the woods
Eibach = Cincinnati customer relocated to Cali, not sure his job title.
Now most likely when you installed the new springs, you did the finally torquing without the cars weight on the suspension, thus binding the bushings and not letting it settle properly.
93 maybe 94 coupe
Discussion Starter #20
Oh I haven't installed springs. Just did the swap/delete work and BOOM. Instant nosebleeds. Totally made note to do that though, but figured I'd rip rubber if I torqued it down in the air. Didn't even think it'd change the ride height, but I bet it would huh.
I'm just tryna figure out where to go to get it sitting right. Bout to forget the bilsteins if they don't get back at me tomorrow and just buy the touring cup kit.
1 - 20 of 34 Posts
