1 - 4 of 4 Posts
P
ok i have a d15b6 (hf motor) and i have a dohc zc ecu and my motor still revs at 5500 and not at 8 im thinking it's the tranny but im not for sure also could i use 1.6 pistons in my block with a 1.6 head?
your better off picking up a dohc zc that upgrading your hf. you have the ecu for it! :) and yes the pistons would work. make sure you use the comp. calc to get the correct info and C/R.
1 - 4 of 4 Posts
