1 - 14 of 14 Posts
90 CRX Si
Well with a good start from mightyjoe and keto, i've got my car fairly dialed in with Crome. I switched injectors to some 320's so i had to tinker with it some, and I noticed my high-cam timing is still the same as a stock p28 on a p30. I made some passes at the track the other day and noticed my AFR's are about 12.8 to 12.5 at WOT in high cam, so I leaned it out some, but I'm wondering if I should throw some more timing in the high-cam, WOT columns
For those not familiar with my setup, here it is:
A6 block, Z6 head, ~10.1:1 CR, Crower stg 2 Cam, Edlebrock IM, AEM CAI, RC Eng. 320 cc, tuning with Crome.
Heres my tune i'm running now since the adjustments on fuel.
1993 Cobra
i gotta get on a different computer(no crome on this one). I will def take i look and report back. Glad to see your still making forward progress unlike me. hahaha
post screenshots of your fuel and spark maps
1993 Cobra
your low cam fuel has less fuel than a stock p28? I would add as a start, 1-1.25* more to the last 3 columns --- 8,9,B10. See how your afr's look, if its still on the rich side add another .25-.50* more.
Im running 33* wot with the B7...and it runs like a raped ape! No detonation or hesitation or over-heating.
90 CRX Si
33* is a lot of timing, but IIRC won't d15's take a little more timing that a d16? Still, i have room to improve. The track was closed so I got no tuning time.
Changing timing without a measurement tool is dicey at best. There is generally a timing setting where the motor is most *happy* - adding timing past this point won't create much additional power, but will increase the risk of detonation. Generally you find this point and back it off a hair for a street car.
Alternatively, you could make pulls and check the plugs... this is a lot more complicated, and even easier to do on the dyno anyway.
If you are happy with how it runs, I'd call it a day until I could get on the dyno.
2000 Honda Civic Dx
with my y5 block, p08 head, p29's and crower stg. 3 I'm at 28* from 5000 rpm to redline for my high cam map. I'm scared to push it anymore. Use a detcan so at least, you can back off the throttle if you hear det. Instead of using the safety headphones, I switched over to a stethoscope attached to the hose coming off the block. The steth blocks out any other sound and goes toboth ears. It kinda hurts your ears tho with prolong use. G/L!
90 CRX Si
I've got a detcan hooked up just trying to find some mech. stethaschope...I've got a medical one from my stint in nursing school but I don't wanna tear it up, lol. I plan on doing the adding timing until it pings then back it off, but for now I just added 1* on the last 3 columns like Joe suggested, just haven't put the chip in yet.
Unfortunately, there's no close dyno, save one about 2.5 hours but i'd have to tune it myself and i just don't have the time.
1 - 14 of 14 Posts
