1 - 19 of 19 Posts
CR-Vtakin
your mom
I finally got around to installing these with the help of one of my friends that has a shop. Thank goodness for a lift and air tools. These bushings are absolutely awesome. I tore through my rta bushings pretty fast last year with the amount of auto xing I did. The hardest part about all of this is removing the rubber out of the rta. We ended up cutting out the bushing with a saw to get the pin out, removing all the rubber off the pin, then getting a 2 3/4" hole saw and cutting out the majority of the rubber. Then took a right angle grinder and used a wicked rasp bit on it and removed the rest if the rubber. Then took a light grit bit and cleaned the rest of the rubber out. After that you have to press the bushing in. Since the rta was still on the car, we cut out some 1/4" steel plates and drilled some holes in them. You put 1 plate on one side of the rta, then lube the bushing up and then put a bolt through the other plate with the bushing on that and press the bushing in by tightening the bolt down. Really easy, just a little time consuming.
I noticed a difference just driving around town before I drove home from his shop. I got to test it on 33.6 miles of twisties all the way home. These things are amazing. They tightened the rear of my car up so much. When you hit a reflector in the middle of the road, you can notice the stiffness by the "thud" it makes. The handling has definately improved compared to what it was before. I would highly reccomend these to anyone. I paid $26 for the 2 bushings and they are definately worth it.
2001 Z3 Coupe 3.0i
I guess you'll really know when you start autocrossing. Though I wouldn't want the harshness or binding, I suppose its easier to live with than the snap oversteer youd get from toasted bushings, right?
Adia's Daddy
2004 Honda Element
transzex said:
so what are you gonna do about the rear suspension binding up now?
ive read about this in a few boards. the autox guys say to get the mugen hard rubber bushings but they are still rubber and will deteriorate over time, probably not as fast as oem rubber but they will still deteriorate. ive seen 99 civics come into the shop here with realtively low kms that have cracked or almost shot trailing arm bushings.
how will the suspension bind transex? not tryin to be an ass, just very curious as to why some of the hardcore autox people are against these bushings? im not a suspension guru so i am not quite sure why if they're bad a company like ES would make them?
any links or info would be great transex if yo have it.
ive had mine for a few years now and there's no noticeable problems with them.
the rear arm travels in a arc, the rubber bushings have just enough give not to cause any binding. The ES bushing limit travel, therefore the suspension goes into bind, really screwing with the spring rates.........aka snap oversteer.
Adia's Daddy
2004 Honda Element
i understand a bit better.
i guess for autox that might be an issue but for daily driving and street use my civic seems to do okay.
oem rubber wears out way too fast and is far too soft for my liking. i could not believe the play in the bushings when i took them out (which were still good btw). ive read that the mugen units are considerably harder however they are still rubber and prone to deterioration, wear and breakage as with any rubber. i like the idea of not having to change out my trailing arm bushings for a long time thanks to the resilliance of polyurethane.
im sure im not well versed in autox enough yet to notice this snap oversteer however my car handles wonderful on the street (which due to financial constraints is where it spends most of its days and probably will for quite some time) and ive become acustomed to the increased stiffness from having all my bushings polyrethane now.
my suspension is set up so stiff for dry pavement street use that movent is very limited.
go hit the brakes at 75% and try to avoid say a tire in the road.
AKA emergency situation.........
Do this in a open lot from about 35-40 mph, your gonna find out what I mean.
Gets even uglier at higher speeds.
CR-Vtakin
your mom
I think I might go try this sometime this week and see what you mean about the suspension binding up. When I brought the car home the other night, I had to come back 33.6 miles of nothing but twisties that are pretty brutal and I felt nothing of the sort. I am curious to see how the car reacts if it does bind up, so time to find a big parking lot to test this since auto x season doesnt start until May for me.
Adia's Daddy
2004 Honda Element
i'll have to give that test a try out in a parking lot tho when i do put it back on the road and see if i can notice it. maybe it's one of those scenarios where it has happened but because i wasn't aware of it i just learned subconsciously to compensate for it after driving for a length of time with them.
not trying to be sassy or anything transex but the situation you described (panic maneouvers) has happened to me several times since i had the bushings in addition to uncountable runs out the river road both alone and against other people. i didn't notice anything unusual about the way the car handled. luckily im still here and it's still in one piece :TU:
CR-Vtakin
your mom
well here is an update. they have been on since January 31st and I still have not experienced this so called rear suspension binding. I have dont the parking lot test and still have not noticed this. They work awesome. I still do not have a race on them, but as soon as I do, I will report back how they reacted. I have some absolutely insane mountain roads around here and if this were to happen, I would have noticed by now.
CR-Vtakin
your mom
hondaluver said:
well would these rear trailing arm bushings be ok for like a daily driver car?? one that isn't an autox?? very curious
I have no problems with these in my civic. I drive it daily and it is fine.
CR-Vtakin
your mom
Discussion Starter #16
modsHXcivi said:
did you have to get it aligned after the install
no, we marked everything and put it back where it was before. it would have been a good idea to get it checked just in case though.
so how is it !?! still good ?
1 - 19 of 19 Posts
