1 - 4 of 4 Posts
Hey guys.
Basically going through the process to retro fit some ABS sensors to my rear hubs for the hondata traction control. Quck question - what is the necessary clearance between the ABS sensor and the Tooth pickup itself?
Cheers:)
ej8
Rear wheel??
And i dont know the clearance but it should be a hall or mag sensor. So test it off the car with some tools and you be able to find out how far away you can get.
Also you should mount this to the front wheels. Where the power comes out at.
Rear wheel??
For it to work it needs to know the speed of the wheels not slipping, i.e the rear wheels.
Hey guys.
Cheers:)
What year make and model are you working on?
1 - 4 of 4 Posts
