1 - 10 of 10 Posts
So, my wife might be using my CRX regularly now, so i am thinking to install power steering in my car.
Does any Honda that runs on D16A9 originally comes with PAS that I can plug and play into my CRX?
If not, what are the parts I need? And from which vehicle?And how difficult or easy to install?
I have read somewhere that I should get a steering rack from any 4 door civic with a D series engine? What about the power steering pump etc?
Pardon me as I just got my CRX last month.
Thanks!
I believe concerto did, as well as EH9 which is a eg sedan basically )
I think though that you'll probably have hard times trying to fit it into engine bay
93 Legend L Coupe.
Um, no. There were plenty of A8/A9 cars with PS. When I got my A8, it had a PS pump on it. It fits perfectly fine. You can take the PS from any D-series powered car with a manual transmission and it should simply bolt to the rack.
What size and type are your tires? I can tell you that going from a race compound 205/50/15 to a AA traction 300 treadlife 195/50/15 made a HUGE difference in steering effort.
Does your wife really need PS? I mean heavier CRX SiRs came with B series engines and more accessories in Japan, and were driven by tiny japaneese people, and I am 99% sure none of them came with PS.
CRX ECODiesel Ram
I ran 185/60/14 normal every day touring tires and my wife had no issues with it ever. Even after going to allseason rated performance tires at 195/55/15 she had no issues either. If you start having her dive it now and practice it will seem a lot less effort when she finally drives often, though if she is extraordinarily weak i guess power steering really is the only option.
i am running on 195/50/R15 tyres at the moment.
My wife only has problem when she is reversing into our parking lot... and she has to dao that a few times a day... so yeah.. PAS will make her life a little easier..
however, i always thought that retrofitting a PAs system is more than a power steering pump/pulley. there are the reservoir, hydraulic pipes, belts etc..
so i was thinking it may not be a simple plug and play...
please correct me if i am wrong..
thanks
I dont know if all obd0 ps pumps are the same but when I swapped d15z3 to d16z5 it turned out that pump mounts are different, pulley and belt are different (V for obd0 and vvvv for obd1), high pressure hose to pump is different, so OP can hardly fit a ps from ANY d-series
use a rack from 90-93 integra. and power steering accessories such as pump and hoses from a 92-95 del sol with a d series motor
-The OBD0 SOHC D-series use one type of bracket.
-The OBD0 88-89 Acura Integra have a completly different PS location, meaning differnet mounts.
-The OBD0 DOHC JDM ZC from the 90-91 CRX Si has yet another different PS mounting. It's location is simialar to the SOHC D
You will need the CRX Si ZC PS brackets in order to fit the PS pump like stock. Nothing else I've found will work. I believe the PS pumps between the CRX Si ZC and SOHC D are the same.
that's what i read somewhere...
there were not much information available, as most of the time when this question was asked the OP was told to "wear a skirt", "grow some muscles"... etc.. :(
Yea, its pretty common. We want super soft and easy power steering and power brakes and then go to the gym to lift as much weight as we can.
Way to make sense america.
Just ask your wife if she would like her arms to look more like michelle obamas.... that might get her to stop asking about the PS....
1 - 10 of 10 Posts
