1 - 3 of 3 Posts
Wow, ive posted alot of questions tonight......
anyways, i used this diy fro reference on where to wire the input wire of the dsm resistor box to (input wire meaing, the lonely wire that doesnt go to the injectors.)? http://www.d-series.org/forums/showthread.php?t=63640
It says in the diy to route it to the dead end connector.
i wanted to ask before i did it, but the dead end connector is the one where i pulled the injector wires from originally correct? it doesnt matter which hole i put them in?
thanks
I can't read...
thanks
the answer to your question is yes...
after you plug in the injectors into the resistor box, u take the power wire(usually red) and plug it into the dead end connector.
1 - 3 of 3 Posts
