1 - 14 of 14 Posts
Is there any way other than disconnecting the battery for 30 seconds?
My car has an alarm and i just don't want it to go berzerk after i reconnect. Also i don't really want to set the time and go thru all the radio presets again ;) Any help would be appreciated.
Live,love,laugh,be real
07' Odyssey 07'Magnum
supposedly you can remove the fuse for your hazord light's, i hear this work's if you leave it out 10 minute's...
i dont know if it work's fo sho tho...
Reactions: ardevas09
just has to remove the fuse in fusebox for 10 seconds and it is good! i am at work now i will post the exact fuse you have to remove when i get back home and can check Honda manual.
1991 Honda CRX
its the hazzard fuse
Thanks for the help guys.
So, which fuse and where is it located?
98 Civic EX
i think its the hazard fuse on 88-91 civic/crx and the ecu fuse on the 92-??. the fuse is located in the underhood fusebox.
Discussion Starter · #8 ·
Is it labeled ecu fuse? If not, then what is it labeled? whats the amperage? I saw a hazard fuse so i tried that and still the same no change. And it's a 98 civic dx. Thanks again.
sub-sponsor
93 civic
pretty sure you can just take the ecu out for like 30seconds
98 Civic EX
should be an ecu fuse in the underhood fuse box, remove it for like 30secs and then replace it.
my 96lx the ecu fuse under the hood is the "backup radio" fuse. pull it for 10-30 seconds and its reset, and so are the presets in your radio.
so this is correct then... if so i should recive some rep for being the first to mention it...haaaaa
Discussion Starter · #14 ·
Ok, i tried the hazard fuse and nothing happened, my car is a 98 though. Took out the backup fuse (7.5 amp) and that worked like a charm :TU: CEL is gone and the car runs waaaay smoother now. Radio presets were gone but my alarm didn't go haywire, so overall mission accomplished. Thanks everyone for the help.
1 - 14 of 14 Posts
