sounds like you are clueless :slap:sounds like your 2-3 syncros is at falut as well.
i remember this everytime i see someone blame synchros...sounds like you are clueless :slap:
Out of 800 possible synchros in trannys I've worked on, I've only replaced three and they were all mine. They were damaged when shifter fork exploded.
this is what I did... but I havnt installed them yet....Energy Suspension Polyurethene motor mount inserts, keeps the engine from moving around.
I used to miss 3rd ALOT at the track, this cured it. The set is about $35, but I only use the rear set.......
