1 - 2 of 2 Posts
C
I am rebuilding a d16z6 and was inquirering about the basic parts that I should change while the engine is apart example...water and oil pump, main bearings and seals??? Any list you guys can help me out with will be appreciated.
THX
oil seal, check bearings for clearance, change oil pump gasket, main bolts, head bolts to be safe, timing belt and other belts, crank seal, ...can't think of anything else. a helms would really help you out. after the helms you won't have to ask nothing like this again cause it'll already be in there!
1 - 2 of 2 Posts
