1 - 3 of 3 Posts
when repairing a harness, is it okay to cut a wire and solder a new, same length, 1 size larger gauge wire in? what is the acceptable length when reducing or adding wire? tips? precautions?
lets say i cant get a new harness, would you rather do Image A or B?
Both will work. Use the same size wire. What harness is this for? What wires need to be repaired?
for the connector c401. almost all the connector pin are damaged from a water leak before. and 3 of the wires from the door lock control unit.
1 - 3 of 3 Posts
