1 - 4 of 4 Posts
Shoot me!
2000 hatchback
I've got a quick question on pre 1996 blocks theres an oil control jet between cylinder 2 and 3. Now on 96-00 y7 engine its located in the head now do you have to remove this from the y8 head im puting on or not. was curious cause im reading an article and it says to remove the oil jet but i have the head off and dont see it on the top of the block. was wondering if they just had the jet in a different spot on the older blocks cause i just see a empty hole on mine.
Shoot me!
2000 hatchback
Thanks :smile: i was reading an article in honda tuning were they removed it from a 95 lx i thought i might have it to on the block but thank you for your help i appreciate it alot. Time now to finish up this swap its hot as fuck in jersey 99-100 and humid as fuck and my car is in the sun i sweated for like 10 people today. thanks for the help
9
i have a question...im putting a 95 d16z6 head on a 00 d16y7 block... where is the plug for the oil that i need to remove? in the block or is it in the y7 head?
1 - 4 of 4 Posts
