Well, my 88 STD never came with A/C, and I got rid of most of my A/C parts that I had taken off my CRXs.
Anyways, I'm thinking about fitting in a small window A/C unit(where the rear seats usually are) and just using inverter or swap in a 12V DC motor and just get rid of the controls. Of course, a larger alternator will have to go in or an auxiliary battery(not sure about the power consumption yet, but I'm looking at a 6000-6500BTU unit).
Only think I can't think of right now is the ducting. The condenser will have to be in-car because I don't know if there's connectors that will keep the freon from leaking when taking the unit out or putting it in. Although, a permanently externally-mounted condenser would work better; I'm thinking of just using ducts hooked up from the rear windows, using foam insulation boards to create the mount so to say. Only issue is; I was thinking of one side is exhaust air, and the other is inlet. How the rear windows open up; would this make it difficult for the unit to pull in air? What about air behind the hatch? I don't mind cutting up the hatch because that's easy to replace.
Really, adding a roof scoop would be ideal...but I do not want to do this. If possible, no cutting up of the car at all(at least nothing that's difficult to seal up or replace).
I'll draw up a picture of what I'm trying to do.
