ED6&7. EE4&5, MB1
This is my mainly stock daily driver with 260k miles.
I started to hear rattle from my valve train so decided to adjust valve lash.
What I didn't expect to see is this:
I also noticed that five other bolts were loose and two had already eaten the threads beyond repair.
So time to swap another ZC under the hood and replace the damaged cylinder head of original engine at some point.
Going to threadlock them on future builds.
EG8
Threadlock seems a bit extreme... What size wrench are you using to do the job?
I can't even recall if there is a torque spec for them, but it is farely minimal...
Always check your bolts again after doing all valves.
ED6&7. EE4&5, MB1
17 mm socket and 64 Nm according FSM.
I think you are mixing the rocker arm locking nuts (25 Nm) and rocker end pivot bolts (64 Nm).
You just need to remove rockers and / or cams in order to tighten them.
I just removed rockers and turned cams so that lobes were not in the way.
Let's add some value to the post and add the correct valve lash numbers for stock cams:
Intake 0,13 - 0,17 mm (0.005 - 0.007 in)
Exhaust 0,15 - 0,19 mm (0.006 - 0.008 in)
EG8
Ha! It took you to mention 17mm for me to re-read the OP.
I read this and DIDN'T realize you were talking about those.
I thought you were talking about the valve adjustment lock nuts ONLY. Fail reading. Also only noticed the rocker in the picture and kept scrolling lol.
But 25Nm is under 20 foot pounds, and "most" torque wrenchs don't go that low. Hence why I said I don't recall reading that torque spec off hand.
Either way, now that I caught onto what you're saying, this may be the same rattling sound I am hearing in my CRV! (Which I also just adjusted the valves for as well lol)
ED6&7. EE4&5, MB1
15 valve mode gets about 40.6 MPG. ;)
Web Camshafts 35-030 (115/148e)
OBD1 IM with RDX injectors, AEM SRI
Small-tube 4-2-1 header and 2.25" exhaust
Neptune RTP
ED6&7. EE4&5, MB1
LOL!
What results have you found with those Web cams? I haven't had a set that I've really liked the results from.
They feel quite stockish, no measured results.
Got the engine swapped last weekend but have to retune it and figure out why new one is running more rough.
Swapped cams and complete IM setup over to new engine and switched to lighter JUN flywheel (5 kg / 11 lbs).
