1 - 17 of 17 Posts
HONDA
What brands do you guys have good things to say about?
I don't want to buy a piece of crap, so want to make sure before hand.
Should I buy an aem true time and call it a day?
Thanks in advance.
95 civic coupe
i wouldnt use a tru time from what i have seen around here on d-series
Not 100% sure if that was all the cam gears fault or some other things was going with the head. Never seen a golden eagle go bad I'm on market for one as well. Oh and any anodized purple always gets my vote :bowdown:
HONDA
HONDA
same
Bisi is way over priced. Keep hearing good things about GE
Never finishes (TWSS)
91 Civic SI hb
Any comapny that does state the gear is for 88-00. They should sell two gears for dseries sohc's
HONDA
Never had any issues with my "cheapo" Areospeed cam gear :
The thing that worrys be about the cheap ones are the bolts. I fear they will be cheap bolts and strip or break. What are your thoughts about the bolts?
Edit : nice looking engine btw
93 Legend L Coupe.
Install new bolts. Problem solved.
I will only buy GE gears from now on. The vernier indexing makes it stupidly easy to set the cam timing and the rest of the build is EXTREMLY good quality.
I like the locking design of the Bisimoto gear, but it is heavy and overpriced and I won't support that charlatan.
AEM 3 bolt. Never had it slip, even after dropping a valve.
Never had it break like the 5 bolt ones.
And its indexed correctly, they offer a Y8 and a Z6 one.
Meat Popsicle
91 CRX Si
And it's marked incorrectly
1 - 17 of 17 Posts
