Hey guys and gals. I've done a full bottom end rebuild on the y7. The pull and tear down wasn't so bad for a hatch with 173xxx on the dash. Everything went back together no problem and install was flawless. lol. Car turns over and runs just like it did before I egged the old crank. The new problem is when you start spinning higher rpm's let's say around 3,500 it runs great! Anything after that is power loss and around 4,500- 6k it starts spuddering and "carb farts" bad. It will soak the spark plugs and start missing until that unused gas gets burnt off. Everything was put back in the right spot I think....I've looked around to see if anything is apparent but all looks good..please help me
