1 - 17 of 17 Posts
1990 Civic Si
Ive already searched and only found results about swapping pumps from z6's and y8's.
so the z6 i have had 200 000km's on it (124000miles for you non metric guys)
going for a full rebuild now and just wondering if i should just get a new oil pump or stick with the old one. reason is that the thing costs like another $200 bones for an OEM version and this build has already gone way past my budget.
future goals would be about 300whp. ive been told that these things do last a long time, but then again the pump is already 12 years old (z6 is from a 95).
Do you guys think the pump will hold up? or should i just suck it up and take the hit?
CR-Vtakin
your mom
I reused mine when I rebuilt my motor. It had 140,000 miles on it at the time. my oil pump was within spec of service limits so i reused it.
1990 Civic Si
Discussion Starter · #5 ·
rebuild the old one.
if it ends up being out of spec then go buy a new one
well how much would a rebuild cost? that would kinda be a waste if it was out of spec and i would have to shell out more for a new one.
don't need to buy anything except for some
some solvent/degreaser to clean it up.
some feeler guages.
crocus cloth/very fine sandpaper and a few drops of clean oil
and if you're going to end up using it then replace the seals (should be cheap cheap ~ 5-10 bucks)
I had my old one redone and the guy that did it, bumped up the pressure for me. So i shouldnt have any oiling issues.
1990 Civic Si
Discussion Starter · #8 ·
some feeler guages.
hmm alright ill look into that sounds cheap!
Honda
does anyone know where to buy a higher flowing oil pump other than having theoldone.com modding the stock one? I have 170,000 on mine and i need an aftermarket higher flowing one for my build. its for a z6
thanks
1990 Civic Si
Discussion Starter · #11 ·
new oil pumps are not that expensive, why wouldnt you replace it?
i looked into it, honda dlr is charging like $230+tax. there are some canadian online shops that sell oem parts for cheaper but they dont have the pump right now.
1990 Civic Si
Discussion Starter · #13 ·
i think 200 bux is reasonable to assure proper oil pressure in a fresh rebuild.
ya you are right, i guess ive gone this far and really everything else is gonna be new. might as well no skimp out on something this important.
Honda suggested retial is $159.87 and dealer net is under $100. That is U.S. of course.
I would find another dealer or perhaps source one online. That dealer is is putting a %100 mark up from dealer net which is common, but not great practice.
oh also.. if you don't care if its honda or not i can call the engine parts wholesale place i get a lot of my stuff from and can get a price for you.
1990 Civic Si
Discussion Starter · #17 ·
thanks for the offer but I got a local guy that can get me this pump for 15% off dealer price. and i pm'd you about the oil pump.
1 - 17 of 17 Posts
