I am looking into rebuilding my old distributor with an external MSD coil. This will be for a 92-95 D16Z6 and I have no previous experience working on a distributor.
These are the parts I intend to get
- MSD Blaster Coil 2 (PN 8203)
- MSD Coil Bracket (PN 8213)
- MSD Red Power distributor Cap(The translucent red piece) (PN 82921)
- MSD Power rotor or should I just stick to a new OEM piece (PN 8092)
Looking at the parts manual there is another cap seal and O-Ring to replace. My questions are
- Will I need to get new OEM(Are there aftermarket performance ones?) replacement for both the igniter unit & Internal ignition coil or just the igniter unit.
- Do I still need to have the internal ignition coil physically in there or I can do without it since I will be using the external one from MSD.
- I also see that the MSD Blaster coil 2 has a variant that comes with a ballast. I assume I would need the ballast since I am not running a MSD ignition unit?
and lastly, are my parts number correct?
