1 - 4 of 4 Posts
My current engine seized up on me , have my old d16y7 engine in the garage that’s broke down cause of broken rod bearings , why can I do to rebuild my engine ?
How broken are the rod bearings? What do the crank journals look like? Are the bores in good shape? How much metal was in the oil?
90 Civic LX / 90 CRX HF
Might not be a bad idea to just source a new engine and throw it in there. Depending where you grab it from it may be cheaper than a rebuild.
Reactions: robgoof
1 - 4 of 4 Posts
