1 - 6 of 6 Posts
K
Quick rundown....... did a minime swap (y7 bottom/y8 top) had valves reground and head pnp. bolted everything on and no joy. after two weeks, i got frustrated and took it to my friend's shop....... no compression. all valves bent, etc. new valves in head and had slight compression. result was "blow-by" thru the rings.
what i am trying to find out is: would i get better performance out of boring the sleeves and adding new rings with oversized stock pistons?; what would be the durability of this setup? (i dont want it to breakdown because the sleeves are too thin)
or should i just resleeve, with forged pistons and rods?
My goal is slightly higher compression (10.5-11:1) and something that i could eventually bolt a mild turbo later and still use it as a daily driver...
I want some balls under the hood with mild cost.
If your staying NA, I'd bore it over .020" And get some .020" oversized PM6 (D16A6) pistons. That would net you CR of 10.4:1. No need to resleeve. Stock sleeves can handle .020" just fine. Good luck with your build.
Z
Agreed but if you intend to ever boost the engine looking at 10.5:1 compression is way to high. You would want to be around the 9.0:1 or lower depending on the intended set up. Which in itself depending on what you wish to accomplish re-sleeving or boring, but with a mild set up boring .020 over would be fine.
K
what should i really be looking at cost-wise. They are quoting 1k for boring and pistons with rings and new bearings.
I've gotta make a decision by this Friday (12/23)......
K
So then boring .20 over and using the stock oversized pistons and later boosting around 8-9lbs should work okay?
Z
It would but I would go forged on the pistons and rods for safety because the honda stock rods are pretty weak. And a grand sounds about right.......around.......$300 for pistons, $300 for rods, $120 for head studs, $100 for bore and hone, plus your rings and bearings.
1 - 6 of 6 Posts
