1 - 20 of 32 Posts
So i installed my rebuild S20 transmission yesterday .Took it out for a drive and it shifts great but it does make a grinding /tapping noise.
It's a s20 d16z6 tranny with
- Gear-X first gear
- OEM second gear
- 3th and 4th CRX ZC
- 5th Oem
- Oem 4.4 FD
- Mfactory LSD
- Torco MTF oil
- Carbon synchro's from synchrotech,new bearings and seals everywhere.
- Clutch masters Fx300 clutch and Bisimoto Flywheel.
- New oem throwout bearing,new release fork.
- s40 starter motor
When the car is parked in gear and i start the engine ,put it in neutral it sounds like there's a gear that grinds against the case every 1 or 2 seconds on idle.
Whenever i push in the clutch the sound goes away.
In neutral the sound tends to fade away slowly or sounds not as hard.
When i put car in first or reverse drive a few feet and put it back in neutral the sound is back and sounds harder again.
I think the sound is coming from the primary shaft ,but every bearing is brand new and the correct shims are in place . (Spring loaded and regular shim)
Does anyone have an idea what this could be?
Here's a video of the sound
https://www.youtube.com/watch?v=em3EOzwjA48&feature=youtu.be
Early batch of the GearX 1st?
Had to have an input shaft modified for proper clearance.
I bought the gear back in 2010 from Kiwi,i don't think it was a early batch. I also used the shim that was delivered with it and the different needle bearing case.The gear slided right on without any issues.
Also the sound is coming from the Primary shaft afaik .I don't think the secundary shaft rotates when the gear is in neutral ?Or does it?
The transmission was opened up and put back toghether by a honda dealership because i somehow put in the first/Second synchro sleeve upside down.Making the tranny shift in reverse in 1st gear and visa versa.
Maybe they forgot to put in the Springed shim on the primary shaft ?
I had issues with Hugo's GearX 1st gear build from YEARS ago, took a while to get it right after emails with Jeff/Kiwi and figuring it out on my own.
The teeth valleys on the GearX first weren't cut deep enough. The high points on the OEM mainshaft 1st gear would bottom out and create issues. I found a way to measure and fix it, one of the things I haven;t spoken about in detail here.
Well It does Whine a little in first gear ,but in second gear you clearly hear it grind/rattle again.I also asked Jeff back then if they where the early batch and he said they weren't.
I think that was on the OCO forum.
I'll inspect the startermotor today if that doesn't give any results then i'm forced to get the tranny out for the 3th time and check that first gear. :(
So i took out the tranny today and opened it up .The brand new torco oil that only ran for about 80miles was dark and sparkly .The magnet drain plug also containt metal shavings as wel as de magnet inside the tranny.I can't however see any wear on any of the parts .And i can't see anything that is wrong .
The only thing that wasn't good was the bearing from the countershaft that was a little up.I didn't staked that enough and put it back in place.
First gear ,can't see anything wrong here either...?
Anybody have an idea? Could the final drive gear be upside down?I thought the radiused side needs to be on the lsd flange side.
Is the clutch pressure plate hitting the shifter interlock guide bolt?
Been there....
Nope also checked the clutch pressure plate.
The paint on the pressure plate hasn't been touched and the interlock bolt has no signs of wear.
The only thing i can think off is the first gear might be a early batch or hasn't been grinded properly like Bone said before .But i can't see any signs of it rubbing against the mainshaft.
The 1/2nd synchro sleeve teeth do come close to the reverse gear on the mainshaft.
@ Mista Bone is their any way to see if that first gear hasn't been grinded deep enough?
After inspecting the Gear-X first gear meshing in the oem mainshaft gear it seemed the Gear-X gear was very tight against the oem mainshaft.I didn't noticed any rubbing .I replaced the Gear-X first with a oem first and instantly noticed the difference in clearance and also turning the mainshaft around went really easy.I also installed a MFactory 1/2nd gear spring ,but i also removed that cause i didn't noticed any benefits from getting it into gears.
I just reinstalled the gearbox and started the engine on jackstands and put the tranny into gear.Seems like the noice is gone !!
Afterwords i went for a drive around the block and all seems to be fine ,shifts well ,no weird noices.
I do still hear a a very light whine from the tranny .Could that be the Mfactory LSD?As i'm not using any aftermarket gears ,only a new Oem 4th gear and a oem 4.4 fd.
Anyway as Always thanks mister tranny guru :)
del Sol si '94
Thats not good news. Im planning on using the GearX first gear as well. Any word on how to modify the shaft/gear for proper clearance? Or where it has been spoken about lol
You grind on the mainshaft, I might have posted about it on here.
Del Sol EH6
I also had that problem. I've send the gear to Jeff and he sended me a new one. He told me the problem is in the OEM main shaft. Honda has produced 2 tolerances of main shafts.
I disagree with that, esp. after chatting with Jeff.
It was on Hugo's transmission and I had his 1st gear for a year long time, like years. On Fred's setup, the first gear wasn't an issue, no mods to OEM mainshaft.
I used an ISB inner race to judge how much reduce the gear teeth on Hugo's old mainshaft as it had pitting damage. Once I was happy with the mockup I sent a good mainshaft off to be ground properly, then I had to file/debur each tooth by hand.
I bet I had 10 hours of time (or more) figuring out that puzzle.
Pics were on FB, but I deleted a bunch of albums. I'll see if I have it backed up as I don't remember which ISB (small or large) ISB inner race I used.
However, when spinning the shafts, by hand, without the outer case installed you would have noticed the noise right away. Little things like that bug me...and I make sure it is right before it ships.
and that's why I trust bone with my transmission build. attention to detail ftw
Discussion Starter #18 (Edited)
I don't know how i didn't noticed it before but this was my first transmission build .An experienced ear would hear that right away.
I still have a light 'whine' when riding.I hope this isn't the ISB bearing or the countershaft bearing ,since they're both new but they might be damaged by the Gear-X first gear.I've checked both bearings before assembling everything and they seemed fine to me .(No play no rattling.)
I am however using a new 4th gear on the mainshaft and a used one on the counter shaft.
The old one had it's synchro teeth worn and i found a new oem gear very cheap .(rover)Maybe that creates the 'light' whine ?
I really don't like to get the transmission off the car for the 4th time and replace the bearings again.
The good part of this all is that the car drives wayy better then before.So much more fun to drive ,and more traction with the LSD .
Del Sol EH6
Hmm interesting.. I had two transmissions where you didn't notice anything without the outer case (everything rotated completly free), but when completely assembled you hardly could turn the mainshaft because of the Gear X first gear.
I'm very interested in your pictures.
1 - 20 of 32 Posts
