1 - 3 of 3 Posts
I have a 4 door integra, car is getting body worked. I saw some where that the rear windscreen sits between the rubber and not on the metal itself. Do I just pop out the top rubber and the glass comes out?
Rubber and sealant hold it on. To remove it you remove all of the surrounding moldings and then you have to remove the sealant using piano wire.
1 - 3 of 3 Posts
