I just got done swaping a Y8 motor into my 94 civic hatch and got it running just fine but it's been leaking oil. Now that it's started to warm up i can actually clean the block and stuff w\o freezing my ass off. Any way I found that it's comming from the rear main seal, what is the cause for the rear main seal to blow out???
B20b ef
It's usually from old age, maybe that motor sat for a while with no oil and dried up the seal a bit. If it is actually blown out (I doubt it), it could be from blow-by. It's a cheap and easy fix if you can do it yourself. Good luck
I have seen
contamination
no lubrication on seal at start up burn up the seal
improper installation
age hardening
excessive crankcase pressure (usualy just bypasses the seal however)
damaged cranks (scratches cuts etc...)
torn or damaged seals
Ultimately as long as it isnt crank case pressure or a damaged crank what does it matter? Just replace it
