1 - 2 of 2 Posts
2000 Honda Civic EX
Hey guys. I am in the process of making some upgraded ground cables and tucking everything at the same time. I was looking for a place to hide the front ground and found a place on the block I'd like to move it to, but I do not know what size bolt fits it. On the drive side of the block, up next to the intake plenum is a threaded hole I'd like to move that ground to. I have no idea what size bolt fits in there. I tried one from my Power Steering pump and the bolt seemed to fit but the threading was possibly different so I did not want to force it. I was hoping someone knew what bolt size and thread size is needed for that hole. Thank you!
2000 Honda Civic EX
Discussion Starter · #2 ·
I found a different grounding point. I had removed a bracket from the intake manifold when I removed the power steering. i put the bolt back in there and grounded that tot eh chassis. I will see how things go when I put the battery back in and then get her ready for spring.
1 - 2 of 2 Posts
