1 - 3 of 3 Posts
i have a 90 crx hf i am working on my suspension. ok so far i have 99 si front disk (complete knuckle) w/ skunck2 coilovers and tokico blues. for the rear so far i have 99 si rotors and calipers w/ intertech springs and tokico blues. dont laugh so far i only have a $100 and some trading in to this. so my ? is can i use 92-95 si knuckles and put the 99 si rotors and calipers on them for my ? i can right know get a set of 92-95 cheap
yes, the 92-95 si rear disc's/trailing arm work. I'm pretty sure you have to use the 92-95 si e brake cable too. Have no idea about the 99 si discs. don't really give a shit. I would never do brake upgrades (other then rear disc) unless I was boosting more then 12psi
thanks for replying but it does not help. i need to know if the 99 si rotors and calipers will fit on 92-95 si knuckle. the knuckle do not have disk and calipers on them. have you ever driven a hf over 100 mph. the brakes really suck. about the 3rd time you use them, thet are done..
1 - 3 of 3 Posts
