OK so I just started tuning my car,
first time.
here's the setup
jdm d15b vtec, allstock except exhaust, no cat.
cx d15b8 injectors(why i have to tune).
ostrich, lc1, crome
OK so here's the deal, when i'm cruising around at partial throttle, afr is at high 14's, which is cool, but when i give it LESS gas it immediately dips down to 11-12afr then dips back up.
so say i'm cruising at around 12hg, then drop the pedal back to 20hg real quick, i'll see a huge increase in fuel, EVEN THOUGH if I cruise at 20hg steadily at that same rpm, afr will be at a normal 14somethin.
so basically when I let off the gas completely, I see my afr curve drop WAY down, then jump WAY up(as injectors cut because i'm in gear).
any thoughts???
thanks!
first time.
here's the setup
ostrich, lc1, crome
any thoughts???
thanks!
