1 - 2 of 2 Posts
Hello!!
I want to chip two ecus with Real Time Programming
See this --> PGMFI.ORG - Grassroots ECU Development - Library . EasyRtpV10
I have 2 ecu's:
PM7 88-89 non catalic (out to mod)
PM7 90-91 catalyc (in car).
My car is catalyc, if i use the PM7 88-89 will work well with O2 sensor??
Then the second question is about the RTP instructions that are in library, in OBD0 they tells about not cut M5318, only soldering a few cables and cut 2 pins, this modification is for 88-89 or 90-91 OBD0???
Because my 90-91 uses a 27Cxx external rom.
I want to chip each with RTP.
For 88-89 i must follow special OBD0 instructions??
For 90-91 PM7 i must follow OBD1 instructions??
Thanks for help!
1 - 2 of 2 Posts
