1 - 12 of 12 Posts
Im getting a JDM sohc ZC, reagular deal, about 40-50k on it.
Just wanted to check what all the pre-swap maitanance i have to do.
1. new timing belt
2. water pump
3. oil pan gasket
4. ...
what else should i change, it is my first swap, so i dont want to pull this motor again.
Thanks.
its a 91 civic dx, i already did the mpfi swap.
will be using dx zxels, zc tranny.
So, i can also use water pump and the timing belt of A6, correct?
no it doesnt have the half shaft. Does it mean its not lsd?
oh yea and the spark plugs are a6 aswell, right?
Just called the place again, they said that the motor is copresion tested all cleaned up and ready to go.
Now, i just wanna know if there is any Other seals i have to change?
And probably the biggest thing im confused with is the clutch. What year OEM clutch will work?
Isnt there 3 different years clutches: 88, 89 and 90-91 together?
So, i just need to get the appropriate year clutch?
How will i be able to tell what year clutch i got? And Dx Si are the same right?
Thanks
I got Bit by the Boost Bug
Bmw 528e
Get your clutch for a 91 civic OEM clutch,Not any other seals i can think of man,I;d say go for it at this point....Rear main seal if you want to just to be safe .
yep looks like i got all the info. Thanks alot.
ill let ya knwo how it goes.
ps. greate site btw, i was on h-t mostly before:)
1 - 12 of 12 Posts
