Ok i did search but i just need a confirmed answer.
Should i go with the Acura RDX 410cc injectors?
They are said to have the best atomization, and cost around $50 ea. shipped.
I look up the install, and from what i have read is all i need are the clips and 14mm to 11mm adapters.
I can get all parts from
xenocron rdx
There price is good and i like the fact that i can buy one injectors at a time from an online dealer ship vs dropping $200-$300 at one time. Right now its easier for me to spend $60 a wk then $200 a month at one time. I can save money but its hard when your girl knows you have money and wants stuff.
So my questions are.
1.) Install. All i need is clips, 11mm-14mm adapter, Cut the tap at the top. Do i need different o-rings for the bottom where it goes into the intake manifold? Factory RDX or civic?
2.)Are they good injectors to get? I read something about them being a little slow and lagging some. But easy to fix just by changing the offset.
3.) Will they run on stock fuel psi? I read that to flow right they need 50psi vs stock 43ish.
Power goal is right around 200whp. I know they will flow that much. Just asking about the install and the injectors them self.
Yes i know i can get some RC injectors used for around $100 then pay about $40 to have them clean.(dsm for $60-$80).
But hell why not get new injectors for a little extra right?
Thanx for any help you can give.
Posted in FI because they will go on a turbo car.
