I've got a set of 410 CC injectors from an Acura RDX that I used on my 06 Si. I'm in the process of putting parts together to build a turbo d16, and I was wondering if I would be able to use these injectors for that build. I'd rather use them then try to find a different set, because I know they're close to new and I won't need to have them cleaned.
My horsepower goal is 300 whp
Yes... they should be fine.
If you have any questions about the RDX injectors you can always contact Chris at Xenocron. He's done a lot of research with them.
