1 - 20 of 64 Posts
These are awesome for guys looking to vent out the block, an to weld on some fittings for the valve cover, or make your own catch can.
honda/firebird form.
the one the goes on the back of the block, how will that be able to vent??? right now i just have the black box, with a fitting tapped into the back of it.. but where my pcv valve was located, i just had plugged off, but there was oil seeping out of it.. let me know thanks. and how much just for that one fitting?
D-series are a little different, but the objective is to plug the pcv black box, and use the oil return passeges to vent the system.
Which fitting are you speaking of ? The one with the logo, or the other two ?
How does this work?
Looks interesting :) I dont want to use the black box.
My friend gave me this thing he said I can plug this into the black box hole (when I remove the black box) for a Catch Can drain back system (or somrthing like that)
Ill post pics when I get home today
How does this work?
He probably gave you a freeze plug, the piece with our logo on it replaced it.
formerly Kit88
ek hatch
just plug the black box ???
how the vent the block then???
I´m interested.
I just put another fitting on my catch cand and connect the black box to it.
Is this ok??
Sorry its setup a little different on the d-series, this plug with the RC logo would go in place of the box, then you run that to a catch can.
That looks nice :)
So the opposite two would connect to a catch can? And that is just venting the block correct?
Would I need a seperate catch can to vent the head?
(Sorry Im a newb when it comes to pcv system)
formerly Kit88
ek hatch
price for this 3 fittings please, any combo price for the fittings hose and catch can ???
I think you guys are thinking to hard about a Breather set-up.....In the pic where the plug is that has the RC logo is normally where our Black Box is on D-series motors. This is the only fitting you need for an External Breather System to be added. I'm a noob also, so please correct me if I'm wrong.
P.S. The above pic supplied is of a B-series block.
Yes send me an IM.
You're right, I just stated that up above. The d series only use the place where the breather box should be.
hmmm, so i could acually just use one of the fittings thats threaded, and stick that where the black box was... are they o-ringed also like the freeze plug, and fit snug... if so, price on one of those threaded black fittings, since the d series only has one spot for it to go instead of 2 like the bseries.
formerly Kit88
ek hatch
^Now I´m confused.
Can we see one pic of the plugs on a d-engine ???
^Now I´m confused.
See the RC logo plug in the picture, thats the only port you guys would use, but instead of the RC plug, you'd just use a fitting with a -10 on the other end.
^Now I´m confused.
Shoot RC a PM and tell them to send me a fitting for Testing and Fitment, and then I will post pics of it on my D-series block to clear everything up for everyone! :yes:
can u pm me a price on the fiting for the black box, also I will need a 1/2 to 10an fitting to put in the other end of the catch can.
96,97,92 hatch
SO then bascially with this set up you can also run a hose from the VC to the catch can along with the hose coming off from the back of the block. Correct?
1 - 20 of 64 Posts
