I need your help to setup deadtimes for RC PL4-1200 injectors in order to setup the Injector Voltage Compensation table in the S300 .
I found this info at 43.5 psi fuel pressure
voltage ms
8 2.550
10 2.550
11 2.280
12 2.000
13 1.790
14 1.620
15 1.460
Does anyone have the correct deadtimes data for the RC1200cc injectors?
PD I am using a resistor box because these injectors are low impedance
One way to do it is to set AFR's with stock 240cc injectors to 12:1 or 11:1 by adding to the fuel map, then rescale the map for 1200's and adjust latencies until you hit the same AFR's. You can also target the same AFR's at a certain cruising RPM if the idle pulse widths are still too small at 11:1 AFR or if that's too rich to idle well.
