So i just bought a set of used 750cc injectors. The code on them is SH4-750. I looked into them and it said they fit d b h k series engines but mine dont clip into my harness? is it because its an obd2 harness?
RCs fit OBD1 harnesses without mods, I believe all you have to do to get them to fit in OBD2 harnesses is shave off a small locating ridge on the bottom of the injector
I was thinking of doing that, but id rather not incase i ruin the injectors. Somehow i missed that obd2 and obd1 clips are slightly different. I think ill just order adaptors from rywire to be safe
Not really worth it when When it takes a sec to cut it off with a blade.
But each to his own I know the feeling when you do something simple and cost you more in the end.
I see what you guys are saying with cutting that little tab off. But it seems that the corners on the clip need to be sanded too so that it fits. i just ordered adapters from rywire. Knowing my luck ill fuck up the very last injector and theyll be useless
