there is a guy selling this
rb20det (motor)
ball bearing very quick spool
comp wheel 42x59 (50.6751 trim)
comp cover .50 a/r
turbine wheel 51x43 (71.0880 trim)
.4 a/r there abouts
around 250-300hp max
will this be a nice start up turbo???
Looks like what I just brought. Its a nissa t25/t28. Good for up 300hp should start spool around 2.5k and full boost by around 3.2k, nice starting turbo, kinda like the apexi or eldblock 1500 kit. I also beleieve that wastegate is set around 7-8psi. And yes ball bearing means faster spool and higher rebuild price.
*edit just looked n u dont got the internal wastegate so how do you plan on running it? Also your need a t25 manifold or adapter plate. I can post what I goy when the mail runs and when I gets some bolts for test fitting. If you want
