G
·i recently acquired a '93 SI with about 92000 miles, and im having a somewhat wierd problem with my oil... actually a couple problems. ive searched for a few days both here and on honda-tech, and i havent been able to find anything.
first, it burns oil during vtec. the amount that gets burned varies, but not consistently. for example: in a 5 minute period of running through 1st/2nd gear a a few times, it went from burning oil for the entire duration of vtec to just the upper 500rpm, and then back to all of vtec. it only does it under load, which leads me to beleive its the rings. but why only during vtec? why is it so inconsistent? i replaced the PCV valve and im waiting for a clear day to try and look for burning oil.
second: when i try to check the oil level, i sometimes cant get a reading on the dipstick. it acts like theres water in the oil. all i get is small droplets on the dipstick, and i cannot get a reading of the level as a result. but then after its warmed up, i can for whatever reason get a good reading off the stick. first conclusion would be a blown head gasket, so i drained the oil to check. other than being pretty dirty, there was nothing wrong with it. didnt look milky-brown at all. my coolent doesnt look to bad either.
any help is apreciated.
