1 - 1 of 1 Posts
So I intalled a y8 intake manifold onto my y7, I used a y8 TB and fuel rail but y7 injectors and am using the y7 ecu.
I did the 3 wire to 2 wire IACV Pinout Change and changed the plug, and checked it about 1000 times. Now the thing is that it doesn't make a difference whether or not the IACV is plugged in.
THe idle is about 1300-1700 rpm and is very rapid in hunting or surging. I have listned for a vacume leak but could hear nothing.
The car is only throughing the IACV code P1509 I cannot figure it out why it is doing this can you not use the stock p2e ecu and do the 3-2wire IACV conversion?
Anybody with something to add
1 - 1 of 1 Posts
