1 - 19 of 19 Posts
lets talk about how much I hate surging idle, i have pretty much tried everything to fix it.. why is it that honda's have this problem? almost every single one that i have seen does this???? especially after swaps
ej1
my friend has this same problem on his 94 hatch......surges eveytime time at an idle....we cant figure out what is wrong with it at all
I to have a surging idle from 1k-3k rpms on my 91 crx hf. This happened when converting from obd0 to obd1. I tried adjusting the ignition timing, it goes away but if I turn off the car and start it up again then it surges again.
Btw my cold start idle is at 4200 rpms.
Well you have air coming from somewhere after the throttlebody. So a vacuum leak of some sort. Start checking where the intake manifold bolts to the head and all around the manifold. You can use propane and see if the idle will drop down. Also spraying water and if that takes the idle down...then theres a leak at that point. The reason it surges is because the iacv is bringing the idle down, but your leak is letting in too much air for it to control.
already double checked everything, there are no leaks
singlecizam said:
yeah it is set at 45 with vacuum line off, and they are stock injectors
I would have it at 38-40 tops man..... but depends mine surges a few rpms only when its hella cold out tho....
Shackle me NOT!!!
1995 Honda Ballade
With my searching idle, I eventually got it down to a mixture of things, FITV, IACV, fuel filter, and fiiiiiiiiiiiiiiiiiiiiiiiiiiiiine leak on my vac lines.......
d-series smartass
damn, i couldn't find it. i used to have a bookmark with a link to various causes of surging idles. it was on another forum...
1 - 19 of 19 Posts
